so, does anyone have an actual pic of one of these valve covers on a 1.6. i know that with the 1.8 version, for the breather tube, you simply close up the original hole and make a new hole in the cover and add a fitting to the valve cover. the problem i see with the 1.6 is that you can't use that process on the 1.6 version of the 323 valve cover. from my understanding, on the 1.8 cover you can do this because the crank case breather area on the valve cover extends to the sidewall of the valve cover so drilling a hole in the side still leaves you access to that area, but on the 1.6 valve cover, the breather area does not extend to the side of the valve cover, so you can't just drill and add a fitting. what is the best way of using one of these 323 valve covers on a 1.6 and working out the breather tube setup.
i hope this post makes sense as i am more than half asleep now, but i needed to write this while i still had it somewhat fresh in my mind.
thanks
alex
