1 - 2 of 2 Posts
I'm in the process of swapping the 1.8 in and the person who I got the engine from cut the connections everywhere when the removed the engine. I was looking and they cut the harness for the ignition system and the 1.6 harness and ignition system is not the same so I'm at a standing point and would need some opinions on what to do.
Thanks in advance
If you use all the coils/sensors/etc from the 1.6 and put them on the 1.8 you won't have to worry about the connections. Just switch everything to the new engine and plug up the original harness.
1 - 2 of 2 Posts
