1 - 6 of 6 Posts
Sounds like a loose heat shielding to me, I guess It's the shielding on the downpipe between the headers and the cat. Jack your car up and see if you can move it. It created some really annoying rattling noises on mine.
Engine pulls normally and everything? No misfiring no loss of power?
I have the same problem with mine, I'm 90% sure it's the heat shield like FuFa said but I haven't had time to fix/look at it.
Discussion Starter #4
Nope not a heat shield. Although last week I did find an exhaust rattle and fixed it but the exhaust Mani shield is soild and won't move. A friend told me it sounds like a lifter? Would I be able to tell my taking off the vc? (would it be obvious)
jack up your car and listen in the transmission area. I have a similar noise from my car and it seems like some rocks got into the clutch area since my clutch fork boot ripped.
Is the ac pump still on the car? Kinda sounds like that,
Also, does the sound chanbge with the clutch in?
1 - 6 of 6 Posts
