1 - 6 of 6 Posts
i need help on putting on the starter for my 1.8 to a 1.6L chassis swap, please. there is no room for me to put my hands under the intake manifold .. =\ 99% done with the swappppppppppppppppppppppp omgg =\
p.s ( noah, help me please =D or anybody else!! )
thanks Will =D
Mufasa in Training
Pull the intake manifold. That's the only way I can think of to do it. It's 9 bolts, but you're going to have to pull the fuel rail as well.
The only other option I can think of is to maybe try to reach around through the wheelwell?
Brah.
dang you should not have any issues with this...i was able to get under the intake manifold when installing mine.
also pm'ed yah about this....
Discussion Starter · #5 ·
i ran into another problem, are there suppose to be extra wires/switches/plugs/sensors near the CAS? >:\ .. and what lower radiator hose am i suppose to use for this 1.8 swap..
IT'S SO COMPLICATING...............!!!!!!!!! dang help !!
Brah.
take some pictures we can help you with that.
you have some plugs under the cas
use 1.8L lower radiator hose
1 - 6 of 6 Posts
