1 - 13 of 13 Posts
Miata Master
Hi, I know a few of you have swaps.Here is the questions i have..
1. vac line from fpr?? just put it to the manifold i guess??
2. What kind of bracket ,if any do i need for throttle cable.
3. coolant lines under throttle body.. Cap them or t- them into the coolantlines coming from the oil filter??
Thats really the questions i have.. Any pics of intake vacuum lines and 1.8 swap engine bays would be awesome.. Thanks in advance..
Want to have running by this weekend!
BACK BY POPULAR DEMAND
I took those pictures for you but I forgot to save them before I formatted my camera again. :(
I'll take pictures of all this junk for you, I swear!
The biggest thing is the throttle body and intake. I have the Flyin' Miata throttle body spacer, and a chewed up intake that is terrible. I suggest you look at pictures of Noah's engine bay on this site to see a better solution. Mostly a longer radiator hose.
Nice job, Noah. This almost makes up for you sending me viruses online.
can you take pics of the wire/plugs near the coils? do i keep the 1.8 fuel injectors or do i switch over to 1.6? i need hella help .. =\
Brah.
you use the 1.8L injectors. i dont have my camera so i cant take pics for a few days
i am not sure as to what issues you are running into but post your pics of what you dont know it is and ill tell you where it goes.
you use the wires from 1.6, but use 1.8 injectors.
problem you will have (and no one seem to have a solution) is intake tube will now hit A/C radiator fan and also interfere with upper radiator hose. it is a mess.
a lots of guys are running w/o A/C fan, or have to run thin SPAL fan. also have to modify coolant hose some what.
1 - 13 of 13 Posts
