1 - 9 of 9 Posts
Premium Member
Everyone, who has tried to fit 2DIN unit in NA has learned how difficult this is. As requested many times we made the 2DIN adapter for MK1 and we made it universal. This took time, as there isnt standard for the side fixings for 2DIN opposed to 1DIN.
The adapter solves this however in an elegant way and provides 4 variable fixing points on each side for every possible 2DIN unit on the market. The original frame provided with the unit can be used.
Similar to the radio cages it will make stealing the units close to impossible as the center console needs to be removed.
Made of brushed stainless steel, they will integrate with the well known Jass Performance interior products (cockpit surrounds, HVAC panels, control panels, cup holders, gear surrounds).
Only few are available and ready for postage at the moment, I will keep updating the thread. Please PM to order.
The price posted to USA (or anywhere in the world) is 86$.
Premium Member
Discussion Starter #4
The Miata center console opening is not standard 2DIN one, that makes it difficult and at the cost of improvisation to attach standard adapter cage, that is normally provided with 2DIN radio units.
The adapter provides not only the 2DIN opening in a Miata, but also the fixings in an universal way, so you wont need anymore even the cage.
No pictures yet, but hope to have some ready soon.
Premium Member
Discussion Starter #5
Here we go with pictures. As said, it adapts to any 2DIN unit and to the miata NA center console opening.
Imposrtant to mention, the 2DIN shell/cage provided with the 2DIN unit is replaced by this adapter and should not be used. However the side screw/bolts are model specific and should be reused.
The original front decorative frame clips as usual to the 2DIN unit body:
The unit with the adapter bolts to the OEM fixing points to the center console.
As said, as added value, the adapter makes it almost impossible for any thief to steal your radio:phillyb:.
Premium Member
Discussion Starter #7
These are available in the meanwhile as black and stainless and as standard cage opening or as front opening to act in the same time as a frame (original one wont be used in this case. giving flush look).
These fit the USDM MK1 tombstones? The website shows they fit the European models. Are they the same as the US Miatas?
Premium Member
Discussion Starter #9
They will perfectly fit on pre-facelift NA models, will probably fit also on the facelift ones.
1 - 9 of 9 Posts
