hey gang, check it out. i want to do a 5-lug conversion on my na. now, from the research i've done on the miata.net forum, i found out that the way monster used to do their cars with the 5-lug conversion was that they used the FC RX-7 front spindle on the miata. now the issue is the following the FC spindle will bolt right up to the upper arm on the miata, but not the lower. in order to make it work, the way monster did it was that they basically took a miata lower ball joint and a rx7 lower ball joint, cut them both open and basically made a hybrid ball joint. now my question is the following. i think that having to make a hybrid ball joint seems to be alot of work, especially for a part that can easily go bad or is something that i might have to replace in the somewhat near future. i know it would cost more, but wouldn't it make more sense to just make a new custom tubular control arm that would bolt up to the miata and properly use the standard rx7 ball joint. if done this way, in the future, replacing ball joints would be a snap and you wouldn't incur future costs of having to make a new hybrid ball joint. what do you all think? how hard do you all think it would be to make this type of control arm? i know that accuracy in the construction is key, but that shouldn't be a problem. if anyone can help in this matter, i'd really appreciate it.
also, how would i go about converting the rear to 5 lug? i got tired of searching on the miata.net forum for an answer as the question has been asked but no one seems to want to answer it.
thanks
alex
thanks
alex
