wait really. i drive alot on the freeways and im always like 4krpmFor what though? If you're looking for better ratios don't bother. Even with a 6spd you'll still cruise in like 3k rpmish.
If you wanna be like "Eyyyy girl, check out my car its a 6spd" just buy a shift knob w/ 6 gears.![]()
It's worth about the same as a pound of goldI wonder if there's a 3.6 or something that's swappable. :?
The **** do you mean it won't help?Also as far as I can tell, say you have a 4.3 rearend and swap in the 3.9, still wont help. :fp:
Simply how these motors are.
Explain how you "know" this. :fp:welll my goal is to go turbo and i know the MSM 6sp is stronger than 5 and reg 6 speed
trans so i guess it kinda works out![]()
Actually the 5-speed seems to be stronger than the 6-speed and other then the turbo the Mazda Speed is a stock Miata. Nothing in the engine or trans was changed. The only engine difference is that they used the 99-00 motor with out VVT.welll my goal is to go turbo and i know the MSM 6sp is stronger than 5 and reg 6 speed
