These 6an lines and fittings are an upgrade to your M-Tuned fuel rail (FUEL RAIL NOT INCLUDED) they were specifically made for miy Miata and will will fit all M-Tuned fuel rails (90-93) (94-05) or any Fuel rail if you buy extra fittings.
Upgrade the rubber hoses in your fuel rail to bigger size (just like FM) and never worry about the fuel hose failing again. (145.00 shipped anywhere in the U.S.)
comes with the following:
Two (2) 3/8 to 6an 90 fittings
Two 6an stainless steel lines
one (1) stainless steel T-Fitting
one (1) adaptor for 6an inlet line.
The lines can also be used with the the factory fuel lines but you will need to buy an adaptor fitting to connect a hose line to it.
Thanks for looking at this thread.
Eli
(786) 280-6114
Eli
(786) 280-6114
