1 - 7 of 7 Posts
Hello. I have a 1999 1.6 ( you might never heard of it, but its imported from japan) . Does anyone know if the transmission of 90-93 is the same as my model? beacause i want to replace my clutch and everything from 94-05 is for 1.8. so im asking for purchasing one of 90-93 clutch kits.
thanks in advance.:)
If you have a 1.6 I don't see why your transmission would be assembled any different that mine in the U.S.
So I would order the '90-93 part as it should be the same size and go into your car. If you want to he on the safe side ask the manufacturer the measurements of the clutch and find out your clutch's measurements before ordering it.
my clutch is 200 mm and i think 1.8 is 225 mm if im right.
so if i order a 90-93 clutch it would be ok for my trannsmision then..
thank you fore the info. :)
· Supporting Member
You can use any transmission from 90-05..same for the clutch stuff..IF..and a big IF..you use EVERYTHING..so you can use a 1.6 clutch IF you use the 1.6 flywheel..you can use the 1.8 clutch IF you use the 1.8 flywheel...
· Supporting Member
AS long as you do not try to use the 1.6 clutch/pressure plate on the 1.8 flywheel..or the 1.8 clutch /pressure plate on the 1.6 flywheel you are good...they are not interchangeable..and if you look at them side by side it will be obvious
1 - 7 of 7 Posts
