1 - 20 of 30 Posts
I'm a seller. You're a buyer. Let's make the mag
I am parting out a turbocharged 92 NA (Base Model, No AC or Power Steering) with 198,876 chassis miles and a fresh built motor before loss of oil pressure and bad crankcase noises. Haven't confirmed what's wrong with the engine yet but I will salvage what I can out of it and offer up what's useable. The Boss Frog double-diagonal rollbar and Flyin Miata Frame Rails are welded to the shell. Only thing NOT available for sale are the Kirkey Seats & GO PRO Camera Mount. This Miata dyno'd 243 whp and 207 ft/lb of torque.
All parts will have pictures provided before sale is finalized. Please note, all prices are OBO + shipping. PM me an offer w/ zip code for shipping quotes. (I will work as best I can with you on all items and shipping.) PayPal or Cash only please. I would prefer not to ship larger items, but I'll ship almost anything UPS Ground at buyers expense.
Shell/Exterior/Body
- Rolling Shell w/ hood, doors, trunk, finish-panel, fenders, subframes, manual steering rack, hubs (new bearings, ARP wheel studs) & control arms (Poly + Delrin bushings) SOLD!
- Hardtop (Defroster + Headliner) SOLD!
- Track Dog Front Splitter $80
Turbo System
BEGi S3 smog-legal Turbo kit SOLD!
Good Engine Block (Decked .006) + Bottom End SOLD!
- Eagle H-Beam Connecting Rods w/ ARP Rod Bolts x3
- Wiseco Pistons (.040 overbore, 8.5 compression ratio) x3
- Ishihara Johnson Teflon Crank Scraper (Needs new teflon insert which I can order for $40)
- ARP Main Cap Studs
- ARP Head Studs
Damaged Cylinder Head (Shaved .005 & Rebuilt) SOLD!
- Supertech Solid Lifters
- Supertech Black-Nitride Coated Stainless Valves (Part # MAEVN-1100 & MAIVN-1100)
- Supertech double valve springs (Part # SPR-TS1015-MI)
- Supertech Titanium Retainers (Part # RET-TS60/MA2)
- Supertech Valve Seals
- Bronze Valve Guides
Other Engine & Exhaust System
- TODA Adjustable Cam Gears (Pair) SOLD!
- Supermiata Harmonic Balancer w/ crank angle sensor trigger wheel SOLD!
- MSD (Part# 8239) C.A.R.B.Ignition Coil w/custom miata bracket & Magnecore Ignition Wires SOLD!
- Precision-Cut Cam Gear Accessible Valve Cover SOLD!
- Enthuza Catback (Magnaflow-muffler, mandrel bent) SOLD!
- Magnaflow C.A.R.B. Catalytic Converter (Part # 332304) SOLD!
- MazdaComp Motor Mounts SOLD!
- Moroso Catch Can*SOLD!
- Flyin Miata Setrab Oil Cooler Kit (nylon braided lines not stainless braided lines) SOLD!
Engine Management & Monitoring
- DIY Megasquirt II PNP SOLD!
- Innovate MTX-L Wideband SOLD!
- Flyin Miata Knock Sensor Kit SOLD!
- ProSport EGT Gauge SOLD!
- Autometer Boost Gauge SOLD!
- Walbro 255lph fuel pump SOLD!
Powertrain
- 1.8 Torsen LSD w/ axles: SOLD!
- 5 speed transmission with new front and rear seals.SOLD!
- Supermiata driveshaft SOLD!
- Fidanza 8lb aluminum flywheel (Replaced friction plate; only 1,000 miles of use) SOLD!
- ACT XT Clutch kit (sprung 6 puck clutch)*(Only 1,000 miles of use) SOLD!
Cooling System
- Flyin’ Miata Crossflow Radiator w/airflow fan kit SOLD!
- M-Tuned Coolant Re-Route Kit, (no thermostat) SOLD!
- Moroso Coolant Overflow Tank SOLD!
Suspension & Wheels
- GarageStar Fender braces SOLD!
- FatCat Motorsports non-adjustable Monotube Coilovers w/ Spherical upper mounts SOLD!
- Control arms w/ Polyurethane & Delrin bushings (Delrin upper front only) SOLD!
- RacingBeat adjustable rear sway bar SOLD!
- Unknown Heavy-Duty Racing Front Sway Bar w/ Racing Beat Reinforcement Kit SOLD!
- 949 Racing 6UL 15x8 Wheels (Excellent condition!) w/ Used BFG Rivals (4/32's tread depth) SOLD!
- 949 Racing lug nuts x17 SOLD!
- Full set of Hubs w/ Timken bearings & ARP Wheel Studs SOLD!
- Supermiata Adjustable End Links x4 SOLD!
- Flyin' Miata Aluminum rear subframe brace SOLD!
- Manual Steering Rack w/ new outer tie-rods w/ Energy Suspension Bellow-covers SOLD!
- Flyin' Miata Manual Steering Rack Bushings (NEW) SOLD!
- Flyin' Miata Manual Steering Rack Bushings (Used) SOLD!
Braking System
- Big-bore Raybestos Master Cylinder (Possibly 626?) SOLD!
- Wilwood 'Dynalite' Big Brake Kit (Includes HAWK HP+ equivalent pads, Wilwood proportioning Valve & stainless-braided brake lines) SOLD!
- Rear 'Sport' Brake Calipers w/ Powerstop Trackday Pads, stainless brake lines & Russel Speed Bleeders SOLD!
- Rear 'Sport' 4000 series T3 Slotted DBA Rotors (Disc Brakes Australia) SOLD!
Interior/Trunk
- GarageStar Center console delete w/block off plate SOLD!
- SCHROTH 6-point Racing Harnesses w/Camlock (Driverside Certified Current) SOLD! Passenger Side (Past-spec) SOLD!
- Miata Roadster Tall Angled Shifter Kit SOLD!
- SPARCO Suede Steering Wheel (330mm) w/neochrome screws SOLD!
-NRG Short-hub + Quick-Release SOLD!
- Dashboard (Complete) SOLD!
What brake master cylinder brace is that? I'll take it shipped to 11423. I'm PayPal ready.
It's made by Raybestos. I am not sure for what specific application it was for originally, I'm guessing a bigger Mazda like a 626? It had no problem putting pressure on the Wilwood calipers so I was very impressed with it.
PM'ing you with paypal info
FCM Coilovers
Spring Rates are 550lbs for the Front, 450lbs for the Rear. Front springs are not labeled so I am not sure what brand they are. Spherical top mounts are in great condition, they all move freely, no notchiness or other issues to worry about.
The master cylinder is Raybestos or the master cylinder brace stopper is Raybestos? Im interested in the brace stopper that's mounted Infront of it on the shock tower. Looks to be a Garage Star one.
Oh sorry. Yeah the master cylinder brace is from Garage Star. Like New Condition, works great. $75 shipped.
payment sent for master cylinder brace. Thanks! :)
Discussion Starter · #16 · (Edited)
Engine is pulled last night. Turbo kit remains in perfect condition for whomever gets it. I will have more details about the engine internals soon! Also I forgot to mention it has an oil cooler. Essentially a Flyin Miata Setrab based oil cooler kit with nylon braided oil cooler lines instead of stainless braided lines. I'm asking $275 for that.
Discussion Starter · #17 · (Edited)
RacingBeat Splined Racing Front Sway bar
So after removing this front bar and cleaning it up a bit I should probably ask more for this monster because it's easy to see how massive and well made this bar actually is. This is a splined, fully adjustable, racing sway bar that I've never seen advertised by RacingBeat before? I will stick to my original advertised price, for now. Someone who does a lot of track or auto-x should really pick this up! It is 30mm or 1-1/8" in diameter.
Discussion Starter · #19 · (Edited)
ALL PRICES REDUCED!
All prices have been reduced, everything must go! I really think the shell is a good bargain. It has a rollbar + frame rails + subframes with a complete poly + delrin bushing kit in the control arms. That will save a lot of time building a Miata or just even a Miata-based race car.
Also I inspected the engine last night. Spun rod bearing #1, which damaged the rod and the piston and the cylinder head where the piston contacted the head. Engine block sustained no damage and is salvageable (except the crankshaft, journal #1 is damaged). Cylinder head is not salvageable but the valvetrain is still useable, just needs to be swapped to a good head.
1 - 20 of 30 Posts
