1 - 20 of 53 Posts
UPDATED: 97 partout, turbo kit, coils, wheels, ecu, stock parts
Parts still available have been moved to the top. Items sold are listed at the bottom.
4 RC 550cc low impedance injectors, comes with two sets of wire ends, 140.00
8 94-97 1.8 Stock tan top injectors, 60.00
94-97 Flyin Miata dual feed rail, stainless braided lines, A/N fittings, JEGS pressure gauge mounted inline, 220.00
Spec Stage 3+ clutch kit, 6 puck sprung disc, approx 15k, 220.00
17.5 lb stock 1.8 flywheel, 40.00
3 Panasport 14x7, +20 offset, 4x108/4.25, no tires, 80.00 apiece or 220.00 for the set of 3.
Absurdflow twin turbo setup, for 1.8L, comes with everything you'll need to do weekend install (oil lines, fittings, coolant lines with banjo fittings, filters, hardware) except for the oil drain fittings that go into the oil pan they are already installed. I will sell the pan for another 40. Kit includes manifold, two Garrett 1548 turbos with approximately 20k on them, downpipe with bung for wideband sensor, 3" exhaust out. Kit cost 60 bucks to ship from Texas to NC in fall of 2010. 1000.00
97 1.8 head with 120k, setup for spacerless coolant reroute through the rear of the head, freeze plug installed in the stock front exit location, heater hose fitting drilled and tapped in the rear, cam seals replaced 5k ago, complete underneath valve cover, 100.00
95 1.8 head with unknown miles, complete underneath valve cover, 80.00
94 1.8 head with 104k, complete underneath valve cover, 80.00
3 1.8 shortblocks, assume they are needing full bebuild. Have cranks for each, I know one of them is good to go with stock size journals, the other two need to go to a machine shop. I have some pistons and rods, some of the rods got ruined from bearing failure. Message me if you want the oil pump(s) specifically or not. I will consider separating pieces but would like to sell them with the block and crank paired, and maybe with the oil pan if you want it. 160.00 apiece.
1990 Dash w/clear title, MAKE AN OFFER
Prices are listed in bold. They are not negotiable for now, I am in no hurry to sell. Besides, they are already cheap as hell. Everything is located in Raleigh, NC 27603. If you are interested in multiple items just message me. I am willing to ship just about anything within reason, and at the buyer's expense. I will post pics of everything tomorrow when it is daylight out. All parts are in used working condition, unless otherwise specified. Some of these parts have very little use.
I am not afraid to completely disassemble this car piece by piece if there seems to be an interest for a lot of parts. The only reason I am hesitant to do this is because there is another gentleman in the triangle area who regularly parts wrecked miatas and sells the parts at reasonable prices and he has a lot so I would rather not compete with his business.
The car is basically in full part-out mode. Let me know what you want.
4 XXR 513, 15x8, 0 offset, 4lug universal. Tires currently mounted are brand new dunlop direzza 205/50 on front, kumho ecsta ast 225/50 on rears with 40%. SOLD
Evo 8 intercooler kit, 2.5" tig welded piping, powdercoated black, black silicone joints, currently best configured on hotside for bottom or side mount setups. Pre-intercooler side has bung in place for turboxs bov, SOLD
TurboXS RFL blow off valve, SOLD
Found a package of Viton valve seals I forgot I had, SOLD
Forgot I had a red NRG quick release hub mounted to a momo hub. It's the one in the picture with the driver's door open. SOLD
Sparco shift knob, SOLD
Crown Royal bag/boot, I made it...hand sewn :), SOLD
96-97 MSPNP, comes with IAT sensor but no bung, grounds added to run low imp injectors, SOLD
Innovate LC-1 WBo2, blue gauge, bosch sensor, SOLD
Autometer "Boost by Flyin Miata" gauge, SOLD
99 1.8 head with 100k, with intake, valve shim adjustment done 4k miles ago, complete underneath valve cover, SOLD
Boundary Engineering oil pump gears, barely used, SOLD
NA Flyin Miata Vmaxx coilovers, less than 5k miles, SOLD
NA R-package front lip, repainted satin black. This is an oem part. SOLD
Would you be willing to ship the r lip?
I want that 1.8L twin turbo setup so bad.... For some reason the idea of a twin turbo miata just never came to mind before. Now it has haha. Sorry Im a broke college kid whos basically out of work atm. GLWS.
Gang-Ban Organizer
pics by tomorrow or ban...I'm too lazy to lock and unlock the thread.
Bump for a list of nice parts :)
rear end is a stock open diff with a 4.1 r&p. i'll start posting pics tomorrow, kinda multi-tasking right now. it's the black faced one with the white letters and numbers.
Functionally formed.
I'll take it assuming it's in good working and cosmetic condition and includes all necessary stuff. PM me your PayPal info.
Cr.net is addicting
Is this complete bolt on ready also do you have the hoses for the reroute .
Discussion Starter · #17 ·
Yes it is bolt on ready. I'll also sell the intake along with it for another 40.00. I do not have the hoses. I had to cut them to remove the head. Only hose you need is the main return back to the rad. stock heater in is practically in same location.
Discussion Starter · #20 ·
already spoken for. if that falls through i'll let you know.
1 - 20 of 53 Posts
