1 - 20 of 21 Posts
Hey guys I recently bought a 99 miata. It has a 5spd tranny, LSD, 143k. The car is stock and drives pretty smooth in my opinion. The car threw a CEL a few days ago and now it's in the shop. The mechanic read the CEL with a snap on diagnostic thing and it read something related to the EGR system. Any ideas of what might have gone wrong? Any common problems on the nb with the EGR system?
Any help is appreciated!
It's an incredibly easy fix. Do it yourself! (this is definitely a great problem to take care of if its your first time working on a car).
Figure out how to take the upper intake manifold off. Don't scratch the gasket! Spray the **** out of every hole in the part you took off the car with some throttle body cleaner and wipe it down good. Put the intake manifold back on the way you took it off and snug the bolts back down (dont make them super tight, but snug). Reset the battery afterward. (Just unplug it for a few minutes). If you dont get the code back in the next 50 miles or something, pat yourself on the back.
thank you all for your responses! The shop charged me $50 for cleaning out the intake manifold and intake. They said that if the CEL comes back on, Ill have to replace the EGR valve and sensor. He quoted me $300 for parts and labor. Is that expensive? Is there a DIY to replace the EGR valve and sensor on this forum?
Side note: they said I have a little leak around the valve gasket and rear main seal area. He quoted me $100 and $350 respectively for parts and labor. Is that expensive?
Force McCocken's Admirer
for teh cleaning 50bucks isn;t bad, but i have no idea what they mean by the valve gasket on the rear main, that is a $200-350 job, depending on the shop, they meed to remove the tranny for the rear main.
http://www.miata.net/garage/manifold/index.html
Helped me alot, make sure to keep up where the bolts go by laying them out relative to the engine. Taking the bottom of the manifold is more involved and it can be left on, spray sparingly as to not leave excess cleaner, you could stick some paper towels into the ports to sponge it. Again be very careful with the gasket. While you're at it clean the throttle body, open the valve and clean the ring of carbon you'll see. While taking the TB off you'll unclamp a coolant hose so be prepared with a drain pan and top off the radiator before driving it. When you get to putting it back together don't forget any vacuum lines.
Any other tips please chime in. GL
Whiskey makes me Frisky
cleaning it alone is not a solution. it will come back. there is something to do with the routing of the vacume lines that aids in the throwing of the cel as it can draw enough pressure or something. somewhere on m.net theres a link to rerouting two of the lines that will solve the issue for good. I had the same problem with my 99, cleaned the manifold, light came back, replaced the egr, light came back, rerouted some lines, light stayed off.
Discussion Starter · #16 ·
For future reference, here's a how-to courtesy of RSpeed.
THanks for the very informative video morr!
Yes I will definitely bookmark this link for future reference when I do the maintenance myself.
$100 for vc gasket?! That's ridiculous
That is what I thought too!
btw is there a link or page that tells you what torque specs are required for each bolt when removing and replacing the vc gasket?
EDIT: Also, if anyone does find that link for the DIY to reroute the vaccum line, please provide the link. I tried searching on CR but no luck.
Toque specs and that vacume article should all be on miata.net. Their data base for stuff like that is pretty good.
Discussion Starter · #20 ·
Its been a good 4 days since the CEL came on. Within those 4 days, I have not driven on the highway, just side streets. Earlier tonight, I took the freeway to get to my destination and the CEL came back on.
Seems like I will have to do some rerouting. Anyone in the LA county area wanna give me a hand?:mrgreen:
1 - 20 of 21 Posts
