1 - 2 of 2 Posts
Is there any way to make a head unit work with the bose system? I just got a metra wiring harness and
its all wired and plugged and no sound. Looked it up and found all the BS about bose systems and how awful they are designed. Am I doomed to buy another (scoche) wiring harness with the line level thing or am I missing something? thanks
To directly answer your question, check for a light green/black wire in the harness that goes into the car. I think that is the Bose amp turn on wire and could be a reason you are not getting any sound.
Most likely you will not be happy with the sound unless you toss in one of these.(Usually you can grab them from Walmart)
1 - 2 of 2 Posts
