Back in the saddle with an NB this time with some slight rust issues. Got it off a friend for cheap earlier on this year and I've taken it down to a bare shell to sort out all the rust and seam weld all the things.
It wont be quite daily status when it's back together since the AC has been ditched but my goals are to sort the chassis so it will handle well, get it as light as I can and put down 200-220whp.
In all it's former glory on some depleted uranium 16 inch wheels of unknown origin.
The tear down was immediate and the results were disheartening
Even the sound deadening looked like ass
Speaking of ass. Drivetrain pulled out from under the shell
Windshield base rust part 1
Part 2
Leaky clutch master = paint removal inside and out
I set to drilling additional spot welds in the windshield opening, door openings, jacking seam...pretty much everywhere there were spot welds. Stitch welding was done along other seams. I haven't finished this wonderful job yet.
Engine bay firewall and shock towers done
Rear firewall and transmission tunnel work
Inside fire wall & transmission tunnel work
Rocker panel & door opening spot welds
Jacking seam spot welds. By this point the Tennis elbow was in full swing.
Windshield repair
Interior starting to look presentable. I added some base plate re-enforcements for the Cusco 6 point cage I had left over from my old NA.
I welded in the main hoop and rear legs of the cage. The front half I will be leaving as bolt in but I'll be adding tabs to bolt to the A pillar.
Test fitting a V8R frame rail brace, aka bfh'ing the frame rails.
All the control arms have been painted a Ford gloss grey and Energy suspension bushings installed.
Part 2
Windshield repair
