1 - 16 of 16 Posts
The Platypus
What have you done to the car airbag-wise? Aftermarket wheel, disabled the airbags, what? I've never had the noise but I know that when you take out the cluster, then remove the airbag light, it will beep/make an annoying sound. I've never heard it so I don't know if that's it, but it's my guess.
If your air bag light is disconnected or burned out you will get an intermittent series of beeps.
my car does that to everytime i turn it on i have no clue what it is :cry2: i just learned to ignore it.
its the air bag light , its not allowing the circuit to complete in the guage cluster, so its a chime rather than the light to let you know you have an improper functioning airbag
yup, i can verify this. it happened to me. just replace the bulb, and if you dont want the light flashing you can just solder the wires together if you have a 90-93 and for 94+ you would need a resistor.
1 - 16 of 16 Posts
