:mrgreen:test pipe
Any specific brand?metallic core car... last long than any high flow ceramic cat
OKmagnaflow high flow ceramic, or metallic if you're ballin.
Hammer and prybar. Takes about 15min to clear all the stuff out of it.How you did it?
Did you open the catalytic converter into two, or you somehow drilled it from one end to the other?
Do you think you can put the catalytic converter shell around a test pipe or it will require extensive cutting and welding?
I gutted it and bolted it back up. Not really much too it. It makes my car WAY too loud, but the last couple RPMs climb a bit faster. Not worth it for the added noise and pollution IMO.WOW very nice!!!
Did you cut a straight pipe shape though it or you removed everything?
Damn too bad I already ordered the new CAT![]()
well all the new cars are rocking metallic core cat.magnaflow high flow ceramic, or metallic if you're ballin.
