1 - 5 of 5 Posts
I am installing my Pioneer DEH-1300MP head unit in my 92' miata. On the wiring harness for the head unit, there is a blue (with white strips) wire, with the following description
Connect to system control terminal of the power amp or auto-antenna relay control terminal".
Do I solder this to my "Power Antenna Turn On" blue wire on the http://www.crutchfield.com/p_120707901/Receiver-Wire-Harness.html?tp=2977.
I am using this as a reference and just want to make sure I wire everything correctly.
http://www.installdr.com/Harnesses/Mazda-Wiring.pdf
Discussion Starter · #2 ·
anyone ever install a aftermarket head unit and can answer this question?
or, does anyone know if i need a wire connection for the antenna power, or is that what the single wire (that looks like a audio jack) is for?
(⌐■_■)
get one of the wiring guides from m.net or the internet, they have all of the miata pins labeled in the stock harness. You just match wires. If there is no match, you don't use the wire.
Murse Magnet
that is what i did.
1 - 5 of 5 Posts
