1 - 4 of 4 Posts
Is there any way to make Bluetooth connection with the MSSS2 head unit, or is FM modulator the only way to aux connection?
There are also adapters that basically look like cassettes that have BT transmitters in them. Look on Amazon. There are also probably hard-wired solutions, but would require some creativity.
Sent from my VS986 using Tapatalk
Discussion Starter #3
Ok. Thanks for the tip. I will look for it.
The hard-wired solution, if there is any, I fear would require a quite big internal operation with skills I do not have. A friend of mine altered an MSSS to make it tune in european FM frequences, but this task is something else...
1 - 4 of 4 Posts
