1 - 10 of 10 Posts
My rear passenger brake caliper is leaking fluid where the parking brake cable attaches to the caliper. The seal under the little spring/arm is dipping all over my lower control arm and the inside of my rim. The exact same thing happened about 6 months ago (8k miles), and I ended up replacing the whole caliper and putting in new brake pads.
Because of where I live, I have to park on a slightly inclined driveway. Does using my parking brake overnight, every night cause this seal to wear out quickly or is there another reason?
FYI Im not into e-brake sliding at all...
R U ?
Why not put it in gear?
But I doubt parking on a slight incline would cause this.. I would blame it on poor reinstallation.
Mine is on Rear driver side, need to replace the whole caliper too.. always park on flat area and used parking brake always..
Discussion Starter #5
Im worried that if I replace it again, it will just need to be replaced in another 6ish months
I got a rebuilt caliper from Advance and a new set decent pads for $62 after tax. Advance runs some pretty aggressive online coupon codes and you can pick up the stuff at the store. Check retailmenot and you can save a **** load.
Discussion Starter #9
Do i need to bleed the whole brake system if i only change 1 caliper or can it be isolated to the 1 caliper that i change.
I don't think its necessary, unless you leak a ton of fluid out during the process. I just put a clamp on the line while I replaced the caliper. Probably not the best way to do it, but it worked for me
Administrator
Depends. If you're quick, and depending on which caliper, you can do just one.
Passenger front most likely to just need the one. The other three are varying degrees of less likely.
1 - 10 of 10 Posts
