So yeah, the title kind of says it all. My miata refused to start earlier and i go to check if i had a loose terminal and it turns out to be the whole negative cable is cut in half. I can start it if i touch the wire to the post. What should I do? I have heard that you can replace just the negative cable because it runs through the harness? Any ideas?
