Hey guys,
I took off my throttle body + iscv to fix my idle problem (wouldn't idle below 1200rpm). Anyways, as I was cleaning the butterfly valve with throttle body cleaner, I held it up to the light and saw that some light was shining through. I understand it's suppose to be fully shut, so this is a problem.
I made sure it wasn't the dash pot, or the throttle body screw ( the one we aren't suppose to ever ever touch). The butterfly valve can't be closed anymore beyond what you see.
What should I do? Time for a new throttle body?
and what the hell are those chunky bits on the rim of the BV?
Bonus question: how the hell do you remove the actual iscv from the solid bit? There's only 1 screw holding it in right?
Thanks all
Thanks all
