1 - 19 of 19 Posts
Another test of the low mount. This time I set the focus and the exposure to manual. Much better as it doesn't change when I hit bumps or brake hard.
The audio was filtered in post-prod but otherwise straight from my cheapo DV camera. Next time ill remember to clean the lens and I really want to get out there in the daylight.
Great sounding car. What lights are you using?
thumbs up
i take it wind noise can be taken out post-prod? what program is used ?
DAAAAAAAAAAAAAAAAM!! that was siiick... man i miss driving my NB right now.. i love hitting the back roads around here... best is always at night when no one is on the road.. I need to invest on a Camera for the next run
Very good work there..
Discussion Starter · #17 ·
i used adobe premier elements 10.0. i believe the camera is in the "mouth" so to speak is in a high pressure area so there is less wind noise than at the same speed if the cameras was locate elsewhere. i used several filter including a notch to get reasonable engine sounds. I experimenting with a two mic setup currently.
1 - 19 of 19 Posts
