1 - 4 of 4 Posts
Hey guys, I noticed a clank sound when I shift (when letting the clutch out) coming from the rear end somewhere. I only noticed this after my clutch was changed to an Exedy heavy duty. What could be causing this sound?
Check the driveshaft bolts...and the U-joints..
I have a similar problem, but happens in the 2300-3000rpm range. If the needle goes into that range I hear it. If I keep it at 2500 per say, it's a constant noise.
But it eventually goes away. Is yours the same?
Nah it happens in all rev ranges, most of the time, it won't happen when I shift and step on the gas at friction point of the clutch. But when I release the clutch and then step on the gas then it'll make the noise.
1 - 4 of 4 Posts
