1 - 14 of 14 Posts
Jus installed my Flyin Miata stage 1.2 clutch,
N I performed the Instalation properly, blead the clutch,
New clutch master cylinder, slave cylinder installed.
But the problem I'm having is when I drive the car I'm hearing a wearing noise tht sounds like it's comin from the trans.
Also when im driving the car goes thru all the gears 1-5th
but when I try reverse it works and Baks up, but it's incredibly
hard to take it out of gear (reverse), plz if anyone can help me out it would be greatly appreciated.
Lit like a BranchDavidian
Did you put any anti-sieze or high temp grease on the shift that the TOB slides on? Did you make sure the action of the clutch fork/TOB were smooth before putting the transmission back in? What is the engagement point of the pedal? Have you tried adjusting it?
1 - 14 of 14 Posts
