1 - 8 of 8 Posts
So my brake master cylinder failed it's Out Of Province inspection.... said it's leaking a little.
Anyways, I want to put a new one on, but is a 91 Eunos. Does it use the exact same brake master cylinder as north american NA's? On my way to the parts store... (DRL's and a reverse light failed too :()
Moderator
I am pretty certain it is the same product number. You may want to cross reference a bit online to be sure - also there is an aftermarket one that is quite a bit cheaper - Rspeed carries it I think. Also check with House of Klown (roadcone here on CR.net) and ask Dave - he is in your neck of the woods :wink:
Well I couldn't find the piece on Rspeed...
But I've got a re manufactured one coming in that I gotta pick up today. I guess if it is the same size and holes in the same place, I'm just going to try to use it.
Not looking forward to bleeding my brakes.
Booerns on the DRL. I didn't have to remedy that when I got my OOP... what does a regular CAD miata do for DRL?
Esteemed Member
Well, looks like it's going to be REALLY expensive to ship one over, let alone, within the next two days.
I think, what I might do, is try to take a closer look at mine. It seems to be leaking between the cylinder and the booster. So, I think I might try to gut the re-manufactured one, and switch the internals with mine, see if that works.
And if that fails, then I'm fuxed for now I guess.
the piston in the MC is leaking. i bought a remanufactured one from mazda about 3 years ago. that one is starting to leak now too.
1 - 8 of 8 Posts
