1 - 3 of 3 Posts
Premium Member
CRAZY $499 Spring Special on Wilwood Miata Big Brake Kit
Got a crazy good deal on the Wilwood Miata brake kits....pick ANY of the options and the total is still just $559.98. Even our versions normally over 800 are just $559 on this deal! :phillyb:
Spring Special just $499 INCLUDING the Brake Lines AND Plain or SRP Drilled/Slotted Rotors AND...your choice of Black or Red Calipers! Normally the lines are extra, normally the RED caliper choice is $90 extra, normally drilled and slotted SRP rotors are extra....but everything included on the special.
To put this deal in perspective, normally the Complete FRONT kit with Drilled and slotted SRP rotors, with RED caliper upgrade, with the Lines added, would run over $800.....but on this special just $499. A savings of nearly $300...for a limited time!
Big Brake Kit by Wilwood - RED Calipers - Drilled/Slotted Rotors :: 94-05
Big Brake Kit by Wilwood - Red Calipers - Plain Vented Rotors :: 94-05
Big Brake Kit by Wilwood - Black Calipers - Drilled/Slotted Rotors :: 94-05
Wilwood Front Only Miata Big Brake Kit --Black Calipers -- Plain Vented Rotors :: 90-05
Premium Member
Discussion Starter · #2 ·
Special continues....but note orders are now backed up about three weeks.
Also, had some requests to do slotted only (not slotted and drilled). Yes, can do that on the special but contact us by email.
1 - 3 of 3 Posts
