721 - 733 of 733 Posts
Constantly Spooling
Discussion Starter · #721 ·
Finally found the time to get my COPs installed. Pretty straight forward, but the first harness I made just wasn’t the right gauge wire.
So I did it again and all is well.
Finish the plug and play for 1.6 since I had a spare igniter
Now that they work I can finish up the look of the harness
I’ll just be doing a once over again for everything before the tune day and bring some extra parts and we should be ready!
Constantly Spooling
Discussion Starter · #722 ·
Got my first ever professional tune completed.
Things I learned:
-Time is money
-Make sure you’re absolutely ready to go before you’re there
-Have EBC setup before hand
So background:
Mods:
-Wiseco Forged Rods: 78.5mm/8.5.1
-Manley Forged H-Beam rods
-Supertech Valve Spring Kit: dual springs 49lbs
-New Stock Oil Pump
-Supermiata 6 puck clutch: rated for 340ft/lbs of torque
-460cc Rx7 injectors
-3.9 ratio torsen diff
-Stock 5 speed transmission
-GT82 Turbo, w water lines
-External gated, with Tial 38mm
-Turbosmart Raceport BOV
-Running 10lbs off wastegate pressure
Dyno info:
212hp, 175 tq
Since this is my first time doing this ****, I felt it went well, learned some things, and KNOW there’s more power.
Problems:
MAP sensor was reading about 40-50kpa higher than normal throughout, so I had them tune around it for now until I get a replacement and go back.
Wants:
-New 3 bar MAP sensor
-Flex fuel sensor
-Deatschwerks DW300c FP
-EBC (hooked up and running)
-Another dyno day
Positives:
-Nothing blew up
-No leaks
-Drove it there and drove it home
-Drives a billion times better
-Feel ready time actually get it on the track and find more problems!
Only took 7 years, that’s all!
OH old news, I had an oil feed come loose during dyno prep literally 2 days before.
It caught flames, always ALWAYS have a fire extinguisher, literally saved my ass.
Turbo blanket was soaked, it was quite a site to see with all the smoke behind me but I cut it off and saved the motor too.
Washed all the oil off and tightened the fitting and drove home that night with no issues.
Never a dull moment haha
Mufasa in Training
To quote a friend of mine: it's better to have a good story than a good time.
Constantly Spooling
Discussion Starter · #724 ·
You’re not lying there!
Literally saw smoke coming from the hood but it was small and figured it was finger prints.
Then I drove further and looked behind me and it was just clouds!
Constantly Spooling
Discussion Starter · #725 ·
Well some things have been purchased.
-Flex fuel sensor
-EBC
Good news:
-MAP sensor was set incorrectly in MS, works now
Bad news:
-Need retune for wrong setting of MAP sensor
-Leaking oil somewhere by the oil drain, it was a loose drain bolt as best as I can tell (easy fix), put new gasket on and tighten back up, not sure how it came loose, time to blue loctite everything
-Want brakes and to drive on twisty roads
Constantly Spooling
Discussion Starter · #726 ·
Found my oil leak, simple one it would seem, valve cover bolts were loose. Not sure if they came loose or I didn’t tighten them all the way!
Got the oil changed up and we’re good to go.
Now time for the boost controller
Glad to see it up and running. I had not a smooth tune story. I showed up to Tony’s and lost an injector as I arrived and had to be towed him. But he was a rockstar when I came back.
Get the boost controller?
Constantly Spooling
Discussion Starter · #728 ·
Ahhh that’s super unlucky.... I did indeed get my boost controller but I had it hooked up wrong since I have DIY PNP... but unfortunately I pulled my transmission again
rear main leak... even though I replaced it years ago and just recently got the car running... maybe too much crankcase pressure before I got my catch can setup properly?
Either way, there was a noise I couldn’t find either that was related to driveline noise so I figured let me drop it, replace the seal, make sure clutch is good and throw it back in.....
Hoping to find a 6speed though so I don’t need to do this **** again.
Constantly Spooling
Discussion Starter · #729 ·
Been a little while.... kept hearing a noise while the car was under load.
It was definitely drivetrain related, just sounded like a rattle but couldn’t put my finger on it, also thought I solved my oil leak and that was a lie.
So decided to drop the transmission.... partly to force myself to buy a 6 speed so I didn’t have to do this **** again.
So I bought a 6 speed from Ulrik. Need to put it all in but rear main seal was replaced and it was leaking at the bottom.
Just need transmission jack to put the 6 speed in and away we go, hopefully without the rattle.
Just need to rebuild the shifter, and I think the reverse switch or neutral switch, got the fluid already, now just need time to knock it out.
Failed miserably putting it in with normal jack and said I’ll just wait.
Then actually put the EBC in and flex fuel.
Since I’m not familiar enough and these cars are old, I assume a non-oem fuel filter will be necessary or does it not matter? I’ll do research but just things I’m thinking of.
Constantly Spooling
Discussion Starter · #730 ·
Got the 6 speed in with plenty of hassle.... the 6 speed was the easy part. Minus me forgetting 4 rear main seal bolts after everything was in.
PAIN.
Wanting to avoid taking off the downpipe was just not gonna happen.
Eventually caved and took downpipe off,of course I broke the gawd damn bolts and they broke off inside.
I used 10 grade bolts to prevent them from breaking but it didn’t matter... so this has caused more headache than it’s worth.
Soooo time for an upgrade, working on vband setup and new turbo.
I’d like a Garrett 2871r but need to make sure it comes in vband configuration.
So since I can’t be turbo currently and I needed to move I bought stock headers and put those back on for the time being. Such a sad day but it can move. Glad I held on to the block off plates for the AN lines.
Suggestions of turbos are much appreciated with vband capability... still aiming for 300whp is the goal.
That’s all for now, just waiting for the turbo purchase and Vband setup.
Constantly Spooling
Discussion Starter · #731 ·
Damn it’s been a while again, been busy.
Moved into our new house, finally have a place for Brutus and Shelby together!
Got a new short shifter for the 6 speed from Gracingshifters... looks pretty nice, and it is definitely short compared to stock.
I had a short shifter for my 5 speed so I had to have another, just different brand.
I already said I was getting a new turbo, so I got all that put together and put in the car. Had a buddy help me get the downpipe and rest of exhaust set for Vbands.
From this:
Back to this:
Got all the lines connected, and finally think I got the car bled properly for coolant so we’re good for now.
Took it for some rips, the line to the ECU came off, I guess a zip tie didn’t do the trick anymore. Once that was fixed up we’re back in business.
Holding boost till 10PSI, and it feels great!
Now to get the flex fuel sensor installed, fuel pump, and brakes!
Until next time!
Constantly Spooling
Discussion Starter · #732 ·
Hey all,
It’s hot, so I don’t do much in the garage despite wanting to. Drive it when I get a chance and it’s always the feeling I’m looking for!
More photos from upgrading lighting for the jetstream headlights to LED’s
OLD
Need to shave the inside of buckets down to use these LEDs since it’s a different shape.
After reassembly, the turn signals are built in so I may block off the existing turn signals but we will see I don’t think they are bright enough when the headlights are on so.
LEDS are bright but focused.
Also got a 3D printed filter that fits NA/NB, prevents all the usual crap from going inside the cabin. (Peep the yoga mat)
Need to clean some things up but next step is working on the brakes, long time coming…. Until next time
Constantly Spooling
Discussion Starter · #733 · (Edited)
Another dump of things I’ve done semi recently!
Finally got the brakes completely.
-Wilwood 4 pots up front
-1.8 in the rear
-Wilwood 1” Master Cylinder
-Prop valve
Everything feels pretty solid, not worried about slowing down anymore, no weird shakes…. Now
Problem I ran into was with the wheels being 15x9 -0, they contact the brake caliper in the front normally
Got 5mm spacers, it appeared to clear but under heavy braking could feel a little vibration, so I had 25mm spacer (I know huge leap) and I can drive again.
So flare removal again
I just can’t turn super far without rubbing issues. Still need to re-do alignment but haven’t been able to find the time yet.
I also got my oil feed line replaced again since it burnt through…. Again….I’m not sure why I haven’t being using PTFE lines but I now am for the oil feed.
Old line
Got a new turbo blanket since the old one was done in with oil.
Finally put the car back on the ground, and with the weather finally getting nice again, bikini top went on!
That’s it for now, once I get 10mm spacers for the front we should be good and I’m going for a long drive up north to enjoy this thing for a couple hours!
Still need to do E85 and fuel pump, etc.
