1 - 20 of 24 Posts
Finger lickin' good...
Ok, I know we have several different single threads on here about swapped motor Miatas (possibly a merge or quick links?) I was just wondering if anyone has seen or has pics of other make swaps into Miata chassis'. Motors like SR20's , LS1's, 20B's, 2JZ's, RB26's etc., whatever! Post 'em up!!
Discussion Starter · #5 ·
Like this SR20?
Here's my 91 with the S14 SR20 mocked up. It will ultimately run with an SR20de from an S15; 200hp.
Steering rack position? Untouched
Oil Pan? Custom unit converting to rear sump
PPF? Yup, using that too
Trans? Nissan 6spd
Hood clearance? Stock hood; no modifications.
Completion date? Kids + house + work = 2009 #-o
Iirc, its not much different.
However, you should factor in that the SR20 weight is including the turbocharger and manifolds. I'll see if I can find exact numbers on the site I moderate.
Oh, and BP's weigh around 310lbs, iirc.
1 - 20 of 24 Posts
