1 - 20 of 45 Posts
So I've decided I need to get my car a bit lower to the ground.
I barely clear speedbumps right now (lowered 1-1/4") when I'm alone in the car.
The FM frame rails seem like a good protection against smashing up my rails, as I've read of quite a few people using them here.
I was just wondering how much life I can expect out of them as they're only 2mm thick.
I'm also a bit scared of snagging one of the weight saving cutouts they have on a speedbump.
Can anyone shed some info on this?
Considering the average speedbump here is more than 5 inches tall and has a concave entrance, I'm 100% sure I will scrape on 95% of them :p.
Alexander Supertramp
If you're getting them just for scraping and not bracing, why not just fab your own out of slightly thicker material?
Rehabilitation Officer
5 inch tall speed bump? 0_0
I would NEVER even attempt to go over one, and I rarely let obstacles get in my way :lol:
I have an unusually high speedbump at the entrance to my home. I installed the FM rails last year and drag my car over them at least twice a day, no worries. I have since raised the car and only drag on it with a passenger and a full tank of fuel. The damn bump is so high, my wife's stock height NB would bottom out on it.
do you have to "ricer dance" over them lol
They're everywhere, and 5" is just an average one, they get higher and they're very steep :p.
Edit:
And we have these, a lot of them. Also about 5" high, impossible to avoid or take diagonally.
Edit:
these aren't as bad as long as you know where they are though. you can keep 2 wheels on the side of the street and just roll one side of the car over. These would be a bitch if you encountered them at full speed at night time though and didnt realize they were there. Bye bye undercarriage
Discussion Starter · #13 ·
I smashed over a particularly high one of those once, luckily that was still at stock height so no (noticeable) damage :p.
i have fm rails and they never get snagged. These things take a beating and they are still super straight (just scratches). they are a must have if u dont want to destroy our oem cardboard rails lol
Discussion Starter · #16 ·
I guess I'll be getting them either way then, as anything is better than the stock rails :p.
Your car seems pretty low, so I can imagine them holding up to a beating pretty well.
Mine scrape all the goddamn time and the fronts are kinda messed up from getting snagged on ****. It was so bad that I unhooked my airbags because I was scared I'd hit a really big bump and have them deploy as happened with fabel. Finally just raised the car about 1/3 inch and it's fine now.
1 - 20 of 45 Posts
