1 - 20 of 28 Posts
hey i just picked up my second miata in like 8 years.
first miata i owned was a hand me down from my older brother.
90 mariner blue na with a 1.8 swap i did. caught fire in a shop and had to sadly let it go.
built countless EF civics and had fun at track.
anyway, i picked up a 94 na about a month ago and now i need some advice on how to actually build one for the track (road race).
any advice would be greatly appreciate!
· brontosaurus
For any advise you're goals will need to be listed. Planning on competing in any events or series? Power goals, budget, etc
"Road race" is about as board and general a topic as "make my car fast".
· R U ?
Well, check out some of the builds in the Projects sub forum for some ideas. Generally if you want track suspension.. the hot thing right now is Xida's from 949.. you could also get some Koni Race shocks and ground control coilover sleeves.
jesus christ. worst than honda-tech.
price range
coilovers - $600-$1200
wheels - have my eyes on tr motorsports c3m cheap 15x9
tires - hankook rs2
sway bar - idk
frame brace - welding my own
roll bar/cage - flyin miata
power - just bought a obx 421, intake cheapo 2.5 pipe with mushroom, exhaust will be at 2 1/4 piping to my old honda greddy sp2 (ha)
· Banned
this probably isn't the best forum for you...
hankook rs3>rs2, fm don't make rollbars or cages, get used to the car before thinking of sways (most ppl only do the front), forget NA power mods they're noise makers.
· Premium Member
price range
coilovers - $600-$1200 >just cheap enough to buy garbage. spend a couple more bucks and get FCMs or Xida
tires - hankook rs2 > you can't even buy these anymore
sway bar - idk >Racing Beat tubular front sway, stock or no rear sway.
roll bar/cage - flyin miata > Hard Dog.
power - just bought a obx 421, intake cheapo 2.5 pipe with mushroom, exhaust will be at 2 1/4 piping to my old honda greddy sp2 (ha) Expensive way to make 5hp
· R U ?
· brontosaurus
What type of "road racing" are you planning to do?
Larger font make it more noticeable? Is this just a track day car, or one that will be in a series or event? Rules and their associated points will have a huge factor in what to do to your car. Without knowing the purpose of your car, we might as well suggest you strap dildos to your hood.
Get it?
· Bimmer Challenge - B5
Better look at diff and motor mounts. There is no trans mount so keeping those stiff is a good idea. Also, bushings... otherwise you are just putting lipstick on a tired old pig.
I assume you have done all maintenance and swapped to recommended fluids.
Brakes... rbf600, braided lines, blank rotors and a set of carbotech pads.
Goodluck.
1 - 20 of 28 Posts
