1 - 12 of 12 Posts
90 NA. i replaced bulb, but the problem is still there. im going to replace the socket as well but will this fix it? i hear this is a common problem... where to find cheap parts?
thanks in advance!
nope. is there 2 parts to the socket? i ordered a cheap jobber one but it's a cut n splice deal. no thanks. looks janky as ****.
guess i'll order from the dealer.
Rehabilitation Officer
Did you use a meter to read voltage coming from the connector up front? Check voltages to limit down possibilities. Connector first, then fuse box where the turn signal fuse would go.
ahh! didn't try the hazards yet. my gf just msgd me and said it wasn't working this morning. it was blinking fast last week. now its not at all. i see a lot of NA's with one signal out. just thought it may be a common problem with an easy fix.
if it was blinking fast.. usually indicates a bulb is out. Does the flasher still click tho? I asked the hazards bc they are on a different fuse im pretty sure. U might have a bad flasher
1 - 12 of 12 Posts
