Garage Vary tail light install help needed...
3428 Views 25 Replies 12 Participants Last post by  freedomgli
I got my Garage Vary tail light...I need help installin it since, I can't read Japanese.
Q
1. Do I need to grind tail light opening(rear part of the car ) to fit new round tail light? ( new lights seems to be bit large than the opening)
2. Kit came w/2 flat fiber glass piece that suppose to attatch around old tail light opening?
Thanks! Chris
1 - 20 of 26 Posts
Man, you figured out how to mount those flares on your own and you can't figure out this?
hehe, I just wanted to be sure b4 I bring out the grinder....I know some of you guys already install this kit ,so help me out!
Chris, you shouldn't have to grind anything!
The two fiberglass pieces go on the openings in the metal frame. Use the rubber gaskets off of the stock tail lights and put them between the metal opening and the fiberglass pieces. Each side goes on only one way to be correct.
I have some pics from my install. Let me find them and I'll post them here.
Thanks Tim!
Hey Tim,
I would be real interested in those instal pics to make instructions in Engrish instead of JDM
Q
Thanks! Chris
Sorry Chris,
Sorry you are having trouble
You can call me on my cell anytime
404-431-3830
Best regards
Joseph
Still having problems, Chris?
The pics must be on my other laptop.
Let me blow the dust off of it and find the pics and post them here tomorrow.
Alright, I made a web page with pics!
Make sure to scroll down to read the captions.
http://clubroadster.net/forum/subpages/gvtl/index.htm
your car is going to be tits when install is done! post up pictures when done
I got it installed...thanks alot guys!!
I don't have digi cam :cry: may be Bill can snap some shot for me tomorrow
is there weather stripping between the new smaller light and the new smaller opening? how well does it keep out water?
a vendor posting up his cell on the fourm... now THATS support. Rspeed joe FTW
When I wash the car and spray directly on the back, a little water gets in the trunk. I just haven't taken the time to put a little weather stripping inside.
i know this is an older thread, but you got pics yet of them on?
I'm almost there but having trouble with the reverse lamp wiring. There is a pigtail with connector on the Daihatsu sourced reverse lamp. What does this lamp plug into? The hardware bag has a wire tap in it but I don't know which wire to tap into. Then do I run a single wire through the hole to the lamp? What about ground? Confused :( My shop manual is 400 miles away doing me no good right now.
On a related note, it would be handy if the hardware bag included washers for the mounting bolts. And if you're in the USA you have to drill two holes for the upper license plate mounts because the spacing is different than Japanese license plates.
1 - 20 of 26 Posts
