Review:
GO GET ONE TODAY! It's a huge improvement on brake performance.
GarageStar Quote: The GarageStar Brake Master Brace creates a bridge between the firewall, master cylinder and shock tower, eliminating firewall flex and allowing the driver to regain maximum braking force and increased pedal stiffness. The Brake Master Brace is formed from steel and is powdercoated in a black finish.
Experience with the Brace:
My car is a 1999 base model that is street legal so I can drive it to a from AutoX events. That's all the car is used for, AUTOX.
The Brace looks beautiful and it performance flawlessly. If you've ever autoX or driven your car hard you might notice that right at the beginning of a braking zone there is a little hesitation from the pedal to the brake pads. That hesitation is the master cylinder moving. Now after having installed the Brace, there is no braking hesitation, or soft feel at the beginning. When I stab the brake pedal, the pads engage the rotors.
This improved braking has lead to me wearing my StopTech pads faster then I would like, so now I'm changning my front pads to CarboTech xb8 to give them a try.
As others have said, even on the daily drive to and from the store I noticed a much improved brake pedal feel.
The only issue I ran into is my master cylinder came up short on the brace. I purchased the correct brace for my car model, but I guess sometime in my cars previous life the master cylinder was replace by a shorter unit. However not a problem, fully extended the bolt and we have a hard strong contact.
Master Cylinder braces put in you in SP, and you run in STR. Go back and read Chapter 15 - Street Touring Section 6 - Brakes.
2014 SCCA Solo Rules
Chapter 15 - Street Prepared
Section 6
Vehicles may only exceed the allowances of 13.6 as specified herein.
A. Any brake line, master cylinder, vacuum brake booster, or brake proportioning valve that meets the requirements of 3.3.3.B.12 may be used. This does not allow multiple separate cylinders. A single master cylinder brace may be added provided it is bolt-on and serves no other purpose.
I took this picture as soon as I was finished installing the brace. I did not have the bolt that goes there. I have since replaced the zip-tie with the correct hardware. If I had the OEM intake box I believe that bolt would still have been there.
I race locally and stand no chance against S2000's so it's not really a "winning factor". No one has argued with me about it, I've shown everyone at the track that it's on my car even my fellow STR racers.
By the looks of how far the threaded rod is adjusted out you might have gotten the one for an abs equipped car. They replaced the one they sent me with the correct one. Pricy but works as advertised.
Nakamae Type R Seats Review
Nakamae Japan has long been known as a Miata interior specialist for decades now. Known for making vintage styled, hand made, custom interior pieces, most notably, the quilted covers for everything from the transmission tunnel to hardtop headliners and boot covers...
As promised here is my tire review i wrote for my sponsor. I know some of you were interested but pretty skeptical on an unproven brand. Here you go!
http://www.zestinoracing.com/michael-donnellys-take-zestino-gredge-rs-tires/
I love these things
You can get them here:
http://lrbspeed.com/product/na-miata-full-aluminum-door-panels/
They are a direct swap for the OEM full door panel.
Comes with everything you need to mount it.
The biggest PITA is swapping over your window felt seals. Just gotta bend up the tabs...
Upon receiving this, I gawked at how good the quality is. I've seen other cooling plates made by Begi and Moss Motors and this one is made of a noticeably thicker aluminum finish.
(Don't mind the dirt in the picture, I got too excited to take a picture so I didn't bother to clean it)
What I...
I was part of the group buy for these door bushings and I received them today. First impressions with loosely fitting them to the door cups by hand is that they are a perfect fit on the cups. So I removed the original ones and swapped these in. They were installed initially loosely with the door...
