so recently i did a dashboard swap on my miata
i have a 1990 miata with a 1.8L
the dash came from 1992
currently my tachometer, oil pressure and water temp does not work.
a little bit of research, ive found that behind the golve box, theres a connector plug behind it (the male connector has a foam wrap, female doesnt) well i left that unplugged when reinstalling because it wouldnt fit. the plugs looked liked it was mirrored (can provide pics if needed)
what i need to know, is this the problem? if so, how can i get it to connect, it just doesnt fit, is there some sort of adapter piece I can get?
