1 - 8 of 8 Posts
I washed my motor yesterday morning. And this morning on my way to work my temp, oil pressure, and tach dropped off. The lights still work in the gauges. Any one know what the deal is? My miata is a 94 1.8 if that helps any
For starters there's likely water in your plug wells. Did you use a pressure washer or a garden hose? If you used pressure you have to be a bit more careful when blasting electrical parts. Dry out the plug wells and just drive the car, the rest should just fix itself in time.
brontosaurus
If I'm not mistaken aren't those all off the same fuse? Did you check them? You could of have had a short and popped it. Might be a good idea to just let the car dry out with the hood open for awhile.
Discussion Starter · #5 ·
Used a hose. Mean green degreaser. Where's this fuse you speak of yea my hoods been open all day at work. I did my best not to spray the electronics on the back of the motor
Oh and my signals don't work now either... FML
If water got in the dionagstic box would it cause all that?
Finally figured my problem with my gauges apparently when I added the wedge bulbs to my turn signals a wire came loose and shorted out then popped a fuse, or it was bc the reverse switch for the lights on my trans wires had got pulled bc of ride hight and shorted out. Either way I got my gauges, turn signals, and reverse lights going again
1 - 8 of 8 Posts
