1 - 8 of 8 Posts
so i bought a GC kit for element off a local seller off his honda element.
the spring diameter is 2.5 inches
length of both front and rears is 5.9 inches
rates something like 510 front 350 rear
has anyone fitted these to a miata lol.. reason i got it was it was pretty cheap, but now concerned regarding spring length... although it should be okay since ebay kits use equal lenght springs ~6inches.
help :D
help :D
Those are some heavy duty spring rates, so I hope you have shocks up to the task. The other concern is if the sleeves will fit on your shocks. The sleeves generally have a collar inside that fits over the circlip on your shock.
i have R bilsteins but am considering revalve.
oh yeah its 375 rear.. thanks sid, i couldn't remember the exact # :)
good to know the 6 inch rear spring will work.. i think gc usually ships the kits with 6 front and 7 rear.
a bit of information i haven't been able to find is the diameter of the bilsteins, to see if the sleeves i have will fit. no measurements on mnet either..
You'll want a huge front bar and stock/no rear bar with those rates.
1 - 8 of 8 Posts
