1 - 20 of 50 Posts
Cross-posted from the Flyin' Miata forum to make sure nobody misses it.
Take 4 lbs of unsprung weight off each front corner with our new kit. It puts an aluminum four piston Wilwood caliper on your stock rotors. Fits under almost every stock wheel, too!
Now available!
Well, sort of. We've opened up the group buy. If we can get a dozen orders for these in the next month, we'll do a limited run of them. If they're wildly popular, they might make it into regular stock. The group buy will run until May 7. Since we'll be placing orders at that point, there will not be the chance to send the traditional "OMG I know it ended last week but I missed it can I still get in?" email.
If you want to check clearance, here are the templates:
9" 1.6 rotors
10" 1.8 rotors
The 11" Sport template will follow once the CAD work is done on the bracket. It looks as if a 10mm spacer will allow almost any wheel to be used with the smallest and lightest 9" option. 13" should also be possible in that case.
Flyin' Miata Little Big Brake Kit
Product description
We know that Miata owners are always looking for ways to shed weight. Autocrossers in particular. After seeing a custom minimum weight brake system on a National level CSP car, we figured we could come up with something for everyone. So we knocked 4 lbs of unsprung weight off each front wheel by replacing the stock cast iron calipers with aluminum Wilwood parts. Along with the weight loss, we also ended up with a four-piston caliper for nice even pad pressure. And yes, we said 4 pounds of weight per corner.
The aluminum Powerlite caliper is a fairly new design from Wilwood that`s an excellent match to a quick Miata. It`s compact enough to fit around the small Miata discs, but is nice and stiff and gives even pressure across the 5 square inch pad. Porterfield, Hawk, Carbotech, Performance Friction and Wilwood all offer a full range of pads to choose from. We ship them with a set of BP10 Wilwood pads, which are a good street/autocross choice. Since the pistons are properly sized, the stock pedal feel will not change. Brake balance will not be dramatically affected unless the pads act differently than your previous ones.
These are not intended to be super heavy duty track brakes. For that, we recommend our four wheel big brake kit with the heavier Dynalite calipers and two-piece rotors. These are a good street, autocross and light track option. They have slightly better heat management than stock brakes due to the aluminum caliper, but rampaging V8s on slicks will want more.
Available to fit any 1990-05 stock Miata brake rotor. However, there`s a catch. On the smaller rotors, the caliper sits very close to the wheel mounting surface. You will have to check clearance on your wheels to confirm the caliper will clear. The smallest 9" rotor may require a spacer - a 10mm spacer will solve almost any clearance problem. The 10" rotor setup fits many more wheels, including almost all factory wheels after 1994 - yes, including 14" ones - as well as popular aftermarket ones such as 15x8 or larger 6ULs. 11" should work with almost anything.
Includes calipers, pads, brackets and lines. You will keep your existing rotor. If you`re changing rotor size, you`ll need to pick up a set of the appropriate rotors.
Discussion Starter #5
I expect the smallest version will fit under 13's. The 10" might as well. It's going to depend on the wheel. Download the template and check 'em against yours, then report back.
To answer a question sent to me by PM: black calipers only. Wilwood doesn't offer these in any other finish.
Discussion Starter #8
User name, we had a bit of fun with the name. We could have called it "Wilwood caliper mounting kit using stock rotors" but that's to hard to type :)
invert - if you have those wheels, grab the templates and check. We can only test wheels that we have in-house. RPF1s are always a challenge as they have such a deep spoke design. However, a 5-10 mm spacer would probably avoid problems if there are any.
Discussion Starter #11
No, it won't fit the rear. It's possible that we could design a bracket to fit them in the rear, but that would require dumping the parking brake.
The 10s will fit a 15x8 6UL, but not a 15x7.5. A very thin spacer would probably solve the problem if you really wanted them.
Loves V8s. Hates you.
So. Is this worth while for a V8 doing light track duty and autoX or keep saving for the big brakes..?
keen on these.. I only do trackdays once or twice each month and rarely drive on the street. The tracks around me arent really bad for braking like 4 braking points per lap.. Will there be ok? with some carbotech xp10s and a bias adjuster?
so is the bracket the same for the 9in's or 10in's? i have the stock 1.6 rotors right now, if i were to use these calipers, can i just get the 1.8 rotors and get the calipers for the 10in rotors?
yes
exactly the question i asked him a couple days ago.
Just Jumped the Gun!
Made an order for 10" brakes!
now we need 11 more people!!!
1 - 20 of 50 Posts
