1 - 10 of 10 Posts
Looking to add in a hard-wire to power my GPS. I can manage to mount the unit on the left of the steering wheel, but the wire drape across the column to the aux power outlet is awful.
Where and how is the best way to tie in a power wire into the Miata? Is there a clean way to plug into the fuze box? Pics and parts would be great to see. I've a 2013 PRHT.
Thanks!
There are several blank spots in the stock fuse box, simply add a circuit there.
Or, run your power to the batt w/ an in-line fuse of appropriate size.
Or, possibly install a simple distribution block in the engine bay after the main relay. It would probably be easiest to add a new circuit in the fuse box...
1 - 10 of 10 Posts
