Nothing overheated, it's a small leak inside the head. Kind of explains the compression test results I got of 165, 160, 160, 165 huh?M2-1028 said:Make sure the block is clean before you install the metal head gasket. Use copper head gasket spray for better sealing. Make sure the block is not warped due to overhearting or you will changing head gaskets again and again again, again......
