so my hid ballast got stuck between the coolant overflow and headlight motor on my passenger side during install, i then tried to open my barn doors not knowing this..my headlight only raised about 70% and thats when i noticed. after moving the ballast i could see that the motor arm had gotten jammed up. now i cannot get it to open at all and only works to lower the door after i manually put it up with the knob and unplugging the power harness for motor. the door light indicator on instrument panel stays on all the time now. the motor felt like it was on fire. still works to lower only after i put it up. will either not raise up or only the 70%. did i fry my motor or the relay?? and yes....i know its karma for installing HID in non-projectors..i swear i will take it the HID off if you help me....:littlepony:
