1 - 13 of 13 Posts
Lets talk about Heat Extractors the hood.
I've seen a few options out there, people have used the mini cooper scoop, the for GT500 vent, and Singular Motorsports has developed their own which seems to be the best.
My engine bay is getting heat soaked, my future plans are to build a box around my intake filter, wrap my header and then put an extractor on my hood.
Experts, what are your opinions on the options available to us? I like Singular's but I like the look of the GT500 vent the best.
EDIT: interesting, I just found this option the Subaru bumper vents, see picture below
GT500 vent
Mini scoop
Subaru Vents
I'm no expert but here is another option. I have a polished hood that i plan on doing this to. I believe these are off of a jeep.
Flying Miata makes a similar type but not as long.
They even include some instructions on where to mount them for best heat extraction!
https://www.flyinmiata.com/support/instructions/misc/louvers.pdf
This was the site i found when i was entertaining cutting up my hood http://hoodlouvers.com/
They offer quite a few designs and they even have a miata section in the gallery.
Rehabilitation Officer
While forum users will always promote friends' businesses, and there will always be a level of nut hugging going on.........I can vouch that the singular motorsports products do work really well, but the GT500 vent will work also. Only installed the center vent of the 3 singular vents on my v8 swapped e36, and it stopped my overheating problems. The GT500 has been proven to work as well, many times on miataturbo.net.
Premium Member
But would the GT500 work the same way? I just like the look of it so much more than singulars
Every vent "works" to some degree, but in the same way 100 horsepower "works" and 200 horsepower "works", both move the car forward but one does more than the other.
If you're just looking for some amount of venting and you're really drawn to the look of the GT500, then that's the vent for you.
FWIW, we did direct A/B testing with the GT500. Our louvers flow twice as much air. :smile: But, at least, the GT500 performed better than some of the other vents posted in this thread.
Discussion Starter #8 (Edited)
Very good point
I was also noticing on your Facebook there is a NB with the NC louver pair. How does that compare to your standard NB 3-piece Kit?
I used to use vents from ebay that were intended for marine applications. A search for "bilge vents" will reveal quite a few effective options.
These are the ones that I had before I switched to a different hood. As you can see, air flows out of them and they were relatively inexpensive.
Relatively inexpensive ebay option:
http://www.ebay.com/itm/ALBIN-SILVE...m1c34a3ec1e:m:mss6u9Y42811iL071PI0fVw&vxp=mtr
This is my new versacce setup for one percenters. Air flows out of these vents as well.
Edit: I'm not sure if you care, but some vents will require you to hack up the inner structure of your hood, thereby giving it some of the properties of a wet noodle. I've had a floppy hood before and while not the end of the world, it's also not ideal. I believe the Singular vents were designed around the inner framework so their installation will require less angle grinder hackery and leave you with a firmer hood than a lot of other options.
This is what I did. It's right over top the intake and I've data logged 20 - 30 degree lower intake temperatures with it.
Sent from my SM-N915T using Tapatalk
I'm really surprised the placement of these vents hasnt been the subject of discussion as much as the type. The style of vent is completely secondary to where it is being placed. IMO almost none of these are placed properly but I don't have data to back up my observation. The problem is, neither do most of the vent owners.
Generally speaking, just behind the radiator but in front of the motor is where you want the vent so that air coming through the radiator is drawn through. It needs to be in a high pressure location. Placing vents over the engine or side rails may or may not be doing anything at all for temperatures or airflow. You would need temperature sensors and before/after data.
I work in racing and I'm around teams all the time - of all makes and models, not just Miata. It seems most of the photos as discussion here are relative to looks and aesthetics only because there is no data to show they are doing what is intended, besides claims that, "air is moving through the vents".
Good job to those that have proof - you should show the actual data and how you made the decision to place the vent. It would be helpful to everybody else!
I do have my own heat extractor hood - ViS. Purchased only after destroying my OE hood. Temps where fine before the hood and nothing changed after in terms of temperatures on track.
Roll Bar God
Exactly where we built the vent on this car that you're well familiar with -
By the time we were done with ducting, the car went from not being able to finish 4-5 hot laps in a row to borderline too cold after running a full hard session on a 90 degree day, which means it still has reserves for those 100+ degree days.
You know the owner, in case you want to confirm ;)
This is using the same Radiator as before, BTW.
1 - 13 of 13 Posts
