1 - 4 of 4 Posts
So I need some help. My Cluster lights, radio button lights, and rear taillights won't turn on. I already replaced the dimmer and its good. I also replaced the TNS relay (Which is the middle relay next to the fuse box correct?) with no avail. Any ideas?
Find a wiring diagram for your ride and follow the circuits.
Also, since it's affecting more than just the radio or speedo, I'd expect it to be a fuse/ground/relay issue, like you've already started looking for.
Double check the "room" fuse (10A) in the fuse box also.
Replace the "room" fuse. Just do it.
1 - 4 of 4 Posts
