I'll start by saying that i've checked the "fitment thread" and I am still not sure what would be the best offset for me.
I'm really hoping someone on here can give me a good answer and not just, "check this thread....." for an answer.
So, i'm building an NA and I am set on running 17's. I know just about all of you on here disagree with the 17" wheel but its what I like. Now, here is the issue. The wheel I have found and I want to run is a 2-piece wheel that is basically made to order as far as offset is concerned. For the rear I can either go with 8" or 9.5". I'm pretty sure I can't run the 9.5" as i'm not running flares and I don't want to run tons of camber, so to be safe, i'm leaning towards the 8" rim. I'll be running a 205/40-17 tire on the setup. My big concern is what offset to run. Like I said, they will make me the wheels in whatever offset I want. I want to run as low of an offset as possible to give the rim a bigger lip and give it a nicer look, but not sure what would be the lowest possible offset I can run without having any issues. I do plan on rolling the quarters, but I don't want to pull them, just roll flat.
I already know the sizing i'll be running on the front, so that isn't a problem, I just need help with the offset sizing for the rears.
Can anyone please give me a good answer as to what would be the lowest offset I can go on a 17x8 and not have to run tons of camber. The car won't be a daily driver, but it will see the road as more of a weekend cruiser and occasional weekday ride.
Any help on the matter would be greatly appreciated.
thanks
Alex
thanks
Alex
