1 - 20 of 72 Posts
looks like morimoto minis? How far does the back end stick out? there is a .5" difference versus the FX-rs... Maybe ill sell my retrofit and start a new project. Cus cutting into headlights is fun and addicting
Discussion Starter · #5 ·
Wire harness I got needs a outside power source. Where's a power source in the engine bay that can power headlights? If anything I'll just run a wire from trunk to the bay. Fog light wire is already taken by my fog lights.
Take the lid off the fuse box, remove the 10mm bolt in the center that holds the ring terminal to the distribution block, feed the headlight wire into the fuse box from the bottom, and put the bolt back in, such that it holds both the ring terminal that was there and the headlight terminal in place. This is exactly what I did for the headlight project that I just finished. It's clean, simple, and effective. The main line that goes into the fuse box comes from the battery so there's no sense in running a new wire all the way back there.
I relocated my battery in the 240 to the back as well.
Ran into 3 issues that I'm not going to workout for a while so don't expect update for a while. Less Clarence than I thought. And I broke the cover on one housing.
Are those ebays retro fitted with projectors?
I have the same lights and also doing the same thing I picked up some smaller lens projectors at the local JY today
Discussion Starter · #12 ·
Yeah. Got the shitty eBay housings and retrofitted a projector. Ran them today. Holy ****! These things put everything on the street to shame. Perfect cutoff. Fairly wide. Not s2k wide but lights up both lanes without blinding anyone.
I've had mine for a yr(eBay "projector lens) and the glass is turning yellow just letting u know there gonna turn
1 - 20 of 72 Posts
