1 - 16 of 16 Posts
BACK BY POPULAR DEMAND
Are they side mount or what?
Discussion Starter · #5 ·
bottom. i had to pick up a bride rail to put it in a miata. i'm sure you can fab the stock rails.
I saw online where a guy just re-drilled the stock rail. Not what I wanted to do, but it might be what I end up doing.
Whoops, I wanted to post this in INTERIOR someone move this.
You don't have to have a slider, just select the drop down box that says "No thanks, I don't need a slider." That picture just happens to have one in it.
Speed Tribe OG Member
Just put mine in today. I fabbed some brackets using some thick ass metal. Then I used new Grade 8 bolts to secure them together to the stock rails. Works like a charm.
Discussion Starter · #11 ·
If the stock mounting holes are in the right spot I am grade 8ing it to the floor.
Did you do it already? Post up some detailed pics when your done.. I'm going with the sparco speed.
yeah, I made a couple of brackets out of 1/8" aluminum bar stock, and mounted the front with those, and in the rear I used a piece of all thread as a stud, drilled a hole in the floor, and put a washer and locking nut on it.
Discussion Starter · #16 ·
My seat is still in shipping for another week or so. I am not drilling new holes in the floor, that's a no-no for saftey.
1 - 16 of 16 Posts
