981 - 1000 of 1017 Posts
:suicide: I forgot you were on MS and even after you mentioned it above. :suicide: Looking fantastic!:icon_cheers:
I will find you. And I will kill you.
Discussion Starter #982
Gotta love those senior moments! Thanks for the compliment.
Finally got around to adding some lock nuts to the muffler hanger I added. When I looked underneath I found one nut had disappeared yet again. I was thinking about using Nyloc nuts but someone pointed out the nylon might melt if the temperature of the hanger got high enough. Solution was some all-metal lock nuts courtesy of Ace.
Put those on to back up the regular nuts I had on there, shouldn't be any more issues with that.
I decided to pull the MS harness connections to see if there were any loose wires that might be causing the intermittent CEL. Didn't find anything abnormal, however when I was putting everything back together the power wire to the wideband pulled out of the StaKon. Fixed that with a new connector. Cleaned up my wire routing a little bit too, since I was already contorted it was a good time to do that. I'm getting too old for crawling underneath a dash. Have to do some driving to see if I took care of the CEL once and for all.
Discussion Starter #983
Been a while since I updated this. Got home mid-July and looked into some things trying to figure out the intermittent CEL I have been getting. Some research showed I never connected the white wire for the wideband gauge lighting to ground as instructions direct so I did that. While I was in there I slotted the upper hole for my Megasquirt mounting bracket to make it easier to get the thing in and out. I also pulled the connection harness between the factory harness and the MS to look for any problems with it but nothing presented.
A few days later I changed the supercharger oil. I had noted some leakage past the snout seal so wanted to check on how much was left. Strangely enough I got 4 ounces out of it which is what is called for. Combined with the fact that I only had 2 ounces remaining in the bottle the rebuilder sent me, the logical conclusion is that the rebuilder overfilled it. I used some AC/Delco oil I got off Amazon. I had also purchased a replacement ‘charger mounting bracket from FFS to see if there was any difference between it and the original BRP bracket. There was not so I went back to the original bracket. I was able to remove one of the washers I used for a shim to space the ‘charger snout away from the crank.
I did an oil/filter change, adjusted the center butterfly brace part to give me some more clearance, and adjusted my steering wheel after trying different things to clear the blinking airbag light (unsuccessfully). Thanks to some things coming together I was headed for MATG again this year.
Discussion Starter #984
She gave me some trouble on the way down, again with an intermittent CEL and one time with the battery light coming on after which I was unable to restart her for about 15 minutes (had stopped at a rest area). Other than that she ran pretty well the whole time there. I did more driving this year than last, met new people and reconnected with old friends.
While there I was talking to member from another forum and he suggested looking into leaks from the FO injector seals as a cause for my fuel smell under boost. After considering this and other possible problems with the fuel system, when I got home I ordered a new fuel pulsation damper along with some injector O-rings/seals. I did see some leakage from the ‘charger drain/fill plug so ordered a new one of those as well.
Discussion Starter #985
I was driving to the store one night after getting home and heard a clicking noise that sounded like it was coming from the stereo. After some on-the-fly troubleshooting I realized it was happening when I used the clutch. Suspicion was it was the green plug for the upper clutch switch. When I got home I looked and there the old one was in pieces on the floor. Luckily I had an extra from when I was trying to fix my cruise control problem so got that fixed quickly.
Discussion Starter #986 (Edited)
All my parts came in today so I set about pulling the supercharger and upper intake manifold. Got about 3 ounces of oil out of the supercharger so that needed doing. There was some oil residue in the charge air piping, not sure if this was a result of my using different oil or not.
When I removed the upper intake manifold and the injectors, I saw signs there was leakage past the O-rings on the #1 and 4 cylinders. Pulling the injector spacers showed the O-rings were collapsed:
I was given two sets of O-rings after sending the injectors out for checking, I used the larger set as they seemed to fit tightly but it looks like they were too tight. No way O-rings should have a flat cross-section after just a couple of years. I cleaned everything up and installed new O-rings and head seals using the lubricant provided. Installed the new fuel pulsation damper as well, just in case it was a contributing factor.
The results on a quick test drive? No more overpowering fuel smell under boost. Have to do some more driving to see if that also took care of the CEL.
Discussion Starter #991
About a week and a half ago I took a drive to visit a friend from several forums (bonus points if anyone on here guesses who it was). After a nice visit I drove home with a part in my possession. Good thing too as the one I was using was on its last legs. What might that be? One radiator fan shroud. First, a picture of the Lexan one I removed:
You can see two of the attachment points had broken off. After some aligning and drilling of new holes for my fans, the installed shroud looks like this:
It is a Mishimoto shroud, fits great and now I don't have to worry about fatigue failure (at least as much) of the material used.
I have had gas smell under boost again, but the injector O-rings are not leaking so this should (hopefully anyway) be down to a tuning issue. Heading back to work end of the weekend so that will have to wait for my next time home.
Discussion Starter #994
Why would anyone make a rad fan shroud out of lexan?
You would have to ask the guy I bought it from (he made a few). Honestly that piece is not normally subjected to a lot of stress so it should last. Mine probably broke due to the supercharger bypass hose resting on one of the fans causing some stress.
I would think that heat cycling would make it brittle
Discussion Starter #997
Heat cycles embrittle every material in time (witness stock Miata radiators). The failures on mine look to be due to stress as opposed to heat cycling, as mentioned I am guessing this is due to external force exerted by my bypass hose.
Discussion Starter #998
Finally back home. Picked up my second set of wheels and brought them home yesterday (the ones with the S-drives, my winter tires). Pulled the alternator this morning and dropped it off at a rebuilder. The place has been there for 48 years, I used them for another car's alternator maybe 30 years ago. Kind of weird in this day and age to see that sort of longevity in a business. I did some research while I was away and the symptoms I have experienced points to the alternator going bad. It will be tested, although that may not be a good indicator of the problem since it only seems to crop up after several hours driving (presumably heat related).
