I have had some problems lately with overheating as seen on my datalogs. Did some troubleshooting, it appeared the primary (driver’s side) fan wasn’t coming on or was running at a reduced speed. Further checks showed the fan ran fine with battery power. I also checked the input from the ECU with the A/C running (so both fans should be on), I had full voltage at the connector. Looking at the connector (a Radio Shack piece) it looked like one of the pieces was out of place which could have caused an issue. Here are what the connectors I used looked like, and the one with the connection out of place:
With that going on I decided to upgrade to more modern connectors as shown:
Purchased from Amazon (
https://www.amazon.com/gp/product/B014IU2EE2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) . They are pretty easy to use, you need to put the seals on the wires before attaching the metal connectors.
There were instructions included showing the orientation of the metal pieces so they will lock correctly into the plastic piece. On the female side there was a red plastic piece that the instructions said you could use or not. I found I couldn’t use them as they wouldn’t allow the metal pieces to snap into place. I ended up cutting some back as shown, then they worked as designed:
When you push the metal pieces into place, you can hear and feel them lock. Pushing the yellow wire seals in place required a little persuasion from a small flat blade screwdriver (I wouldn’t use something as small as a jeweler’s screwdriver as you might end up ripping the seal) but it wasn’t too bad. That’s all done, I’ll see how things work next time out.
