1 - 4 of 4 Posts
I got my 94 Miata last saturday.
The car idles under 1k and feels like is about to die and the car shakes.
I changed the oil (looked as dark as oil can get) and filter
Changed the air filter
Spark plugs
and cleaned the MAF sensor.
Any Ideas?
After I have driven the car and i put it on parked the revs go up to 2k and then drop a little the go back up to 2k then goes and idles low. On gear it idles fine... needle just moves slightly.
:hello kitty:
Same stuff happened to me! Try checking your master and slave cylinders if any of them are leaking. Just fixed mine yesterday and the problem disappeared
Beggars can't be choosers.
Could be out of time. Could need injectors or injectors cleaned, maybe need fuel filter. Maybe need fuel pump. May need a MAF. May need coils. Lots of things.
Take off and clean your idle control valve with some electrical parts cleaner. Takes about 5 minutes, but it sounds like your car isn't going to closed loop properly.
1 - 4 of 4 Posts
