I'm trying to install a headless unit in my 96 and bought this 2 channel amp.
http://www.amazon.com/dp/B004V9G3GQ/ref=pe_175190_21431760_cs_sce_dp_1
Everything went smoothly and works but it seems like it still draws power from the battery even when the stereo cord is plugged in. So i thought maybe i can connect a standard automotive relay to use the ignition switch cord to turn the amp on and off.
http://www.amazon.com/Absolute-RLS1...R9GG/ref=sr_1_1?ie=UTF8&qid=1328234979&sr=8-1
So im trying to figure out how to wire everything and wanted to double check before i blew anything.
I was thinking of connecting the relay on the 12v line thats always hot. so from the battery it would go into connection 30 then 87 goes to the amp. Then the line from the ignition would connect to the 86 then the 85 goes to ground. Does everything match up the way im trying to have it work? Thanks!!!
